Ok guys i need help on removing the stm bar on a 350 rappy. the major ting i cant get off is the tie rod ball joints, the one come loose? any special tool i need?? Need help asap thanks.
VIP
Hit the side of the steering knuckle where the tie rod end goes through with a hard faced plastic or a rubber mallot and the tie rod end should come loose. If that does not work then you can install the nut upside down until flush with the end of the tie rod stud and hit it with a hard plastic or rubber mallot. Do not use a metal hammer or you can damage the aluminum knuckle or the threads on the tie rod end.
