I took my carbs apart to replace the o rings. Now I can't put it back. Idk how they are supposed to set back together. Where the spring in picture one goes and the flap in picture 2.
141546
141547
The flap in pic 2 goes between the spring and screw in pic 1. It ties the two throttle butterflies together. It's explained well in the manual - you HAVE downloaded it, right?
Hope you do a little cleaning before re-assembly...
Yes I have the manual. I'll check it out thanks. Yes I plan to clean it up, i just wanted to make sure I could reassemble it first
I still couldn't figure it out. I looked in the manual with no luck. Maybe I over looked it
So did you get it yet?
