When I installed my LTE's, I had a problem with the clearance between the mid pipe and the case. If you play with the angle of the head pipe (twist it up a little bit), it will help with the clearance between the mid pipe and the case. Just make sure you use all of the heat shields and maybe even zip tie any wires away that are close to your installation. I had to use tin snips to modify one of the heat shields so that it would fit. The silencer was also a real tight fit on one side on my bike. Also, FYI...my pipes and a friend's pipes both had minor flaws on our head pipes (mine had a pin hole size hole in one of the welds and my friend had a small crack in the weld). Check them and have them rewelded before you install them. Good luck.
