1 - 2 of 2 Posts
Got a 06 700 but it will start up and run fine for a few seconds then it surges at idle but if i give it throttle it will come out for awhile and do it again and if i go full throttle when i let off it will die ive sprayed everything for air leaks and no leaks ive checked the tps its at .65 volts and im new to the whole efi so anything helps before i send it to the shop
Administrator
Welcome to the forum. Can you provide some more info on the bike, is it all stock or is there aftermarket pipes, filters and such. With an EFI bike, do not touch the throttle while it is warming up, it will foul the plug. Speaking of plug, install a new one and see if there is any difference.
1 - 2 of 2 Posts
