1 - 2 of 2 Posts
i went to take my partor for a ride for the first time since i had it and i got it started i was letting it warm up and oil started pouring out from behind the front sprocket. does anyone have any idea what this would be? and what would cause it?
Bad output seal, remove the sprocket, pry out the old seal and push in the new one. Use caution not to push the new seal in to far, there isn't a shoulder for it to rest agienst. Just push it in till it's flush with the case.
While it's apart look at the sleave the seal rides on, if it has a groove in it, it should be replaced also.
1 - 2 of 2 Posts
