1 - 9 of 9 Posts
2006 raptor 700...today i went riding and hit a few bumps on the dirt rode the my raptor shut off. i tried starting it an it wont start. however i turned the key switch off and back on again and it crunk up and i took off but it shut off again. once i got it started again i took off again and it shut off as i was riding it. now as long as i pullled the clutch in an turned the key switch off and back on it would start up and i would take off. so i had to continuely pull the clutch in, tune the key switch off and back on it would start. thats how i make it home...so what would cause it the shut off while riding continuely?
Uhm i dont know but ill give this thread a bump up for you. I hope one of the pros on here chimes in for you.
Do you get an error code at all?
You need to read the code...count the flashes..after the pause is the second number..
+1
If you have the manual, there's a list of the codes in there.
Its says its the crank shaft position sensor in the fault codes.
Discussion Starter · #8 · (Edited)
could the lean air sensor cause that problem. i notice that the 2 bolts and nuts were gone and it was flopping around. i crunk it up an layed the sensor down an the bike shut off. i remounted the sensor and it stayed runnung.
Well its a start if its still running after you fix it LOL.
1 - 9 of 9 Posts
