1 - 12 of 12 Posts
I just got a 2007 350 raptor from a friend i dont know much about atvs anyway when you turn on the key you have power the lights are on and bright but the bike will not even turn over some people say that it is the stator can you please help me i dont want to keep buying diffrent parts and it is not the problem thank-you!!!
First things first.. Did you check the killswitch?
Forgot to mention
Also when the key is on and the bike is on nuetral the green light is not on but when you shift it to reverse the red light turns on im not sure if that also helps with my problem
Okay, battery connections? Where the clutch lever connects, there is a wire there, make sure the whole thing is pushed in the clutch perch all the way. That is a common problem that is usually over looked.
Still having problems
Okay i check the wire by the clutch it is all the way in.i tried using the screw driver on the starter it is turning over i check for spark but there is no spark i also took off the kill switch and cleaned it with contact cleaner still the same wont turn over by switch please help!!!!!
I was having the same trouble with my daughters Polaris 90. I bought it used and it wouldn't start using the start button. The previous owners would use a wire kept underneath the seat and used it to touch from the battey to the silinoid and it would turn over instantly. I sent months trying to fix it, replaced the relay, cleaned the kill switch and not wanting to pay a machanic to fix it, I installed a push button start from the battery to the silinoid and it works perfectly...for now.
What is the voltage of the battery?
1 - 12 of 12 Posts
