1 - 2 of 2 Posts
Ok i was riding in a field and it was running great all the sudden it made a small backfire noise and acted like it was locked up so i took it to the barn and bout 3 minutes later had my buddy pull me and poped the clutch it ran for 3 senconds and shut off and did it again so i go it home and pulled the valve cover nothing is broke timing chain is in good shape but i know the one-way has been going bad on it so i got it off and put a scoket on the crank shaft and it turned over perfect both directions had great compression and everything the one way was gone when i pulled it off all the bearings fell out of it but i put a socket on it and it turned over great has this ever happend
Welcome to the forum!
Your one way is gone... details sound pretty common.
re not running, check your carb to intake boots, carbs may have popped off due to backfire.
1 - 2 of 2 Posts
