Ok i turn on my raptor no problem. But after about two mins of riding it the thing will die. then it wont turn on for like five mins. Then it will turn on but will only idle for like 30 secs then die......
anyone know what is wrong? or what i should check or do to it?????
start by making sure your gas is good, make sure all your fuel line flows with no restriction, it could have something in the float bowl an its getting caught in a jet or the float is getting stuck but in that case you would get either too much fuel and it would drain out the overflow or you wouldnt get enough fuel. check your spark plug an filter. also check the battery while its sitting, while your cranking an if it starts while its running an make sure take note of the voltages. well try that an see what you come up with, its all about troubleshooting.
