i was told my needle in my carb was sticking because on idle, the revs will somtimes get stuck and high rev..
the guy told me to dump a bottle of carb cleaner in the gas tank and ride with that, would this help? is it ok for the engine??
It could also be your slides in the carbs. over time they get rough or dirty which will cause them to hang resulting in the hanging rev when you let off. Also check to be sure your throttle cable is not binding up and causing it.
