OK, so it seems like "until I need to" has arrived. I am going to be attempting to swap out the piston on my bike with a stock size 11.5:1 piston that I ordered from TQS.
Any of you guys that have done this before have any suggestions or comments that I may find helpful? Any special tools required? I know ill need a ring compressor, what about a ring file?
Also was wondering what kinda power increase I will see with this mod.
The previous owner had the engine rebuilt with a JE stock replacement piston and told me it was dynoed at 61hp. This seems kinda high to me for the mods it has.
You don't need a ring compressor. The stock cylinder has a taper at the bottom that makes it easy without a ring compressor. You need a head gasket and a base gasket, loctite, and a torque wrench. Any small file will work to gap your rings. You will also need to replace your coolant.
As far as tips go...Download a manual and don't drop your cam gear bolts in your crankcase.
Thanks. Got the torque wrench, loctite(RED), gaskets being sent from TQS as well. Will get coolant.
When you install the wrist pin and C clip....put a rag under the piston so "when" I mean if you drop the clip it won't end up in the bottom of your motor...and for me it was easier to install one of the C clips on the piston first on the work bench, they are a PITA to get in. then you only have to fight one when its on the rod.
the service manual calls for a piston pin removal tool?
