1 - 17 of 17 Posts
Well getting new chain for the new swingarm. Now the ? is with or with out the oil rings. Whats the diff. Some pros and cons please.
go with an o ring chain they last alot longer and they dont stretch nearly as bad
O-Ring all the way! I highly reccomend a riveted mater links over the clip style. I've seen a few machines loose the clips this summer, mighty messy!
O ring seals in grease for longer life, less maintenance. The con is drag. Non o ring chains offer more power to the serious racer types. Most pro MX bikes heave non o ring but they get new stuff every race .
Well thanks to all. But think I'm going with a non o-ring chain. Going to order a DID ERT gold chain.
O-Ring will last at least 10X, but will cost you about 1 hp.
Up to you to decide which is better for you. And keep in mind that a chain with moderate wear will wear out your sprockets as well, so change the non-ringed chain out frequently or plan to replace sprockets with it.
keep us posted on that chain ..
I bought sidewinders BEST chain and they claim it will only need 2 adjustments in a year I have to adjust mine every second weekend :(
Wow, don't want that. Well sparky recommened this one he runs. The DID ERT chain I'll give it a try. Thank for the info because I thought that the sidewinder chain would of been a good one to run on the bike.
Hippy said:
they did make good tho
sent over 2 sets of sprockets and chains
Thats cool. Its alway bad to hear bad about a product or company but I think its alway better to hear that they made good on there product.
first thing i did is get rid of the o ring/ theres several companys that make strong non o ring chains/ o ring chains r restrictive / they kink up / less hp :(
Oring chains are fine as long as you keep em clean and lubed properly. Id stick with the oring imo.
ended up snapping the new chain.. and broke my case...
I guess I ride to hard LOL..
non o ring chain will last just as long as an o ring chain if you maintain it.
1 - 17 of 17 Posts
