1 - 2 of 2 Posts
I just installed a new gytr clutch on my raptor i pre-soaked the clutch plates before installing them. I did everything from the book but abviously i missed something please help im going to glamis this thursday... thank for the help in advance.... :help:
I'd start with removing the clutch cable from the motor and see that the arm that the cable hooks to is in the correct spot, allowing the clutch to disengage that is.
After removing the cable you can grab the arm with a pliers and turn it untill it contacts the pressure plate, you'll only be pushing agienst the spring thats under the arm. Note this position and compare it to where it was when the cable was attached.
Or you put the steels in in the wrong order.
1 - 2 of 2 Posts
