Alright i just got my ebay/solux combo in the mail. Im using two sets one are replacing the stockers and the other are being mounted on the bars. On the bulbs i got 2 10 angle pencil beams and 2 36 angle flood lights. My question is should i mount the pencils or floods up on the bars or should i put one pencil on the frame and one on the bars? Also when wiring to the stock harness should i use the high or low beam wire as these are not dual stage lights
When you order just one kit you will get 1 pencil and 1 flood and I would use the low beam.
Yeah but i got 2 kits so should i mount 1 pencil on the bars and 1 on the frame? Usually i understand you just put one on each side but since i ordered two pairs i figured i could get better lighting by using either 2 pencils or 2 floods on the top the vice versa mounted on the frame
