1 - 13 of 13 Posts
I just put on a new Tag steering stem +1 with Pro Taper SE Raptor Bend 7/8" bars. Now the clutch cable and brake hose are tight. Is this normal? Will I have to get longer cables?
I think your going to want to be going with a shorter rise handle bar.
Yes if you went with a +1 stem you needed to go with a bar that is more like the CR hi bar. It has less rise. Or you can buy new cables. It would probably be cheaper to sell the bars you have and pick up a bar that has the lower rise. I think Rockymountainatv.com has a chart with all of the heights.
I'm a taller rider at 6'4" so I like the feel of the high rise that I now have.
Can anyone tell me where I can get: 1. a longer brake hose, 2. a longer clutch cable, at a good price.
Thanks
Motion Pro has +2 clutch/ +2 throttle cables
their website has them listed in new parts, and they're a reasonable price
however, they don't have a listing for an extended parking brake cable, so you might need to move that and maybe even the switchbox...
you might even want to make the switch to aftermarket brake lines. I've seen some on ebay for $65, Chaparral has some for $63, and Rocky Mountain atv has Tusk brand for I think $58
I was looking into some Rox risers, but the Tusk risers that I have already stretch the cables quite a bit. They're still within spec when I turn full lock either way, but if I wanted to try more height on the bars, then that would be going too far.
I made a post about replacing the throttle cable in 'discussion', refer to it to see if it'd be worth your while to go that route. :thumbsup:
Here is the info from Rockymountainatv.com
Compare to the cr hi and you should be fine.
This shows all the brands. I have a Tag +1 stem the Cr Hi in Pro Taper contours 1 1/8 bars. I am 5'10" 215 and I am happy with this setup.
Factory 909 Bend Width Height Pull Back
ATV Bend 32.01" 4.25" 3.07"
Banshee Bend 30.51" 5.91" 3.94"
CR High Bend 31.60" 3.70" 2.40"
CR Low Bend 31.60" 3.10" 2.30"
GP Bend 31.02" 3.66" 2.28"
Honda OEM Bend 31.34" 3.50" 2.28"
Kawasaki OEM Bend 31.69" 3.66" 2.17"
KX Bend 31.70" 2.80" 2.70"
Mini Low Bend 28.20" 4.10" 2.60"
National Bend 31.90" 3.70" 2.00"
Suzuki OEM Bend 32.04" 3.11" 2.32"
Team Bend 31.60" 3.80" 2.10"
Team Tall Bend 31.60" 4.00" 2.30"
Yamaha OEM Bend 31.61" 3.62" 2.24"
Back to Top
Fly Racing Aluma-Steel Bend Width Height Pull Back
ATV F Bend 29.76" 5.51" 4.05"
CR High Bend 31.34" 3.50" 2.12"
Kawasaki/Suzuki Bend 31.49" 2.79" 2.16"
Mini Bend 29.13" 3.77" 1.65"
Vintage Bend 33.07" 6.77" 3.54"
Yamaha Bend 31.61" 3.62" 2.24"
Back to Top
Longhorn Big Bars Bend Width Height Pull Back
ATV High Bend 31.50" 4.75" 2.37"
CR High Bend 32.00" 3.74" 2.45"
CR Low Bend 32.00" 2.80" 2.68"
KX Bend 32.00" 2.80" 2.36"
Mini Bend 30.00" 3.94" 2.53"
RM Bend 32.00" 3.23" 2.87"
Universal Bend 32.00" 3.39" 2.76"
YZ Bend 32.00" 3.31" 2.95"
Back to Top
MSR Carbon Steel Bend Width Height Pull Back
ATV High Bend 31.50" 6.00" 3.94"
ATV Low Bend 31.00" 4.00" 3.62"
CR High Bend 31.63" 4.50" 3.80"
CR Low Bend 32.13" 3.63" 3.50"
CR Mid Bend 32.25" 4.25" 3.38"
KX High Bend 31.50" 4.25" 3.07"
KX Low Bend 31.88" 3.25" 3.38"
Mini High Bend 28.50" 4.60" 2.36"
Mini Low Bend 28.13" 3.71" 2.36"
RM High Bend 31.88" 3.75" 4.13"
YZ High Bend 32.25" 3.88" 3.75"
YZ Low Bend 31.50" 2.64" 2.76"
Back to Top
MSR Dominator Bend Width Height Pull Back
KTM High Bend 32.72" 5.24" 2.14"
Mini High Bend 29.13" 5.88" 3.75"
Mini Low Bend 28.125" 3.71" 2.36"
Back to Top
Moose Steel Bend Width Height Pull Back
ATV High Bend 32.50" 5.00" 3.20"
Back to Top
Pro-Taper Contour Bend Width Height Pull Back
ATV High Bend 31.50" 4.75" 2.17"
ATV Low Bend 31.50" 3.74" 2.37"
ATV Mid Bend 31.50" 4.25" 2.21"
CR High Bend 31.50" 3.74" 2.37"
CR Mid Bend 31.50" 3.23" 2.24"
Carmichael Bend 31.50" 3.00" 2.17"
Factory Suzuki/KTM Bend 31.50" 3.63" 1.85"
Henry/Reed Bend 31.50" 3.62" 2.24"
KX High Bend 31.50" 4.25" 2.21"
Mini High Bend 30.50" 3.74" 2.00"
Mini Low Bend 30.50" 2.80" 1.85"
Pastrana FMX Bend 30.50" 4.75" 2.17"
Pastrana MX/RM Low Bend 31.50" 2.91" 2.17"
Raptor Bend 30.30" 5.64" 3.41"
Universal Low Bend 31.50" 2.80" 2.17"
Windham MX/RM Mid Bend 31.50" 3.90" 2.13"
Woods High Bend 30.50" 3.74" 2.45"
Woods Low Bend 30.50" 2.80" 2.37"
YZ High Bend 31.50" 3.31" 2.00"
Back to Top
Pro-Taper EVO Bend Width Height Pull Back
Carmichael Bend 31.50" 3.0" 2.17"
CR High Bend 31.50" 3.74" 2.45"
Windham/RM Mid Bend 31.50" 3.90" 2.13"
Woods High Bend 31.50" 3.74" 2.56"
Back to Top
Pro-Taper SE Bend Width Height Pull Back
ATV Low Bend 32.00" 5.50" 3.30"
ATV Mid Bend 32.00" 5.90" 3.00"
ATV High Bend 32.00" 6.30" 3.94"
CR Low Bend 31.50" 2.80" 2.68"
CR Mid Bend 31.50" 3.23" 2.36"
Factory Suzuki Bend 32.00" 3.63" 1.85"
Henry/Reed Bend 31.50" 3.70" 2.17"
Honda Mini Bend 28.75" 4.60" 1.97"
KTM 50 Bend 25.50" 3.15" 1.75"
KX Low Bend 31.50" 2.80" 2.36"
KX High Bend 32.00" 4.25" 3.07"
Kawasaki Mini Bend 28.75" 3.71" 1.97"
Raptor Bend 30.30" 5.63" 3.41"
RM Low Bend 32.00" 2.91" 2.17"
RM High Bend 31.50" 3.23" 2.87"
School Boy High Bend 28.10" 3.46" 1.77"
School Boy Low Bend 28.10" 3.07" 1.85"
Suzuki Mini Bend 28.75" 4.00" 1.97"
Windham/RM Mid Bend 32.00" 3.90" 2.13"
XR50 Bend 28.50" 6.75" 1.75"
XR Bend 31.50" 3.23" 2.83"
YZ High Bend 31.50" 3.31" 2.95"
Yamaha Mini Bend 28.75" 3.90" 2.28"
Back to Top
Renthal Bar Bend Width Height Pull Back
ATV Honda/Suzuki/Kawaszki Bend 31.10" 5.59" 3.54"
ATV Race Bend 30.51" 4.72" 2.68"
Banshee Bend 30.51" 5.90" 3.93"
89-91 CR Bend 31.29" 3.74" 2.44"
CR Bend 31.30" 3.74" 2.44"
CR Mini Bend 29.13" 3.78" 2.68"
Fourtrax Bend 30.31" 6.30" 3.86"
KTM Mini Racer Bend 25.28" 3.31" 1.73"
KX Bend 31.69" 3.66" 2.17"
KX Mini Bend 26.57" 3.54" 2.68"
KX/RM Mini Bend 28.82" 3.94" 2.48"
LT-R 450 Bend 31.65" 3.50" 3.23"
Mini Carmichael/Allessi Bend 29.13" 4.65" 1.65"
Mini Racer Bend 30.20" 6.06" 2.76"
Raptor 700 Bend 31.10" 5.55" 3.54"
Raptor Bend 30.90" 5.51" 3.94"
96-01 RM Bend 31.49" 2.79" 2.55"
RM Bend 32.05" 3.11" 2.32"
RM Mini Bend 28.94" 3.54" 2.72"
RMZ Bend 31.42" 2.91" 2.28"
Suzuki Quadracer Bend 30.31" 4.72" 3.62"
XR Bend 31.69" 3.43" 2.28"
04-05 YFZ 450 Bend 30.43" 4.33" 3.82"
06 YFZ 450 Bend 30.70" 4.17" 3.46"
YZ Mini Bend 28.74" 4.06" 2.32"
YZ/WR Bend 31.61" 3.62" 2.24"
Back to Top
Renthal Fat Bars Bend Width Height Pull Back
ATV Bend 31.29" 3.74" 2.44"
CR High 31.29" 3.74" 2.44"
Carmichael High Bend 31.57" 4.49" 2.13"
R. Carmichael 31.57" 3.89" 2.12"
J. McGrath 31.61" 3.62" 2.24"
KFX 450R Bend 30.26" 3.78" 2.83"
KTM 03 Bend 31.81" 3.27" 1.40"
KTM 04 Bend 31.80" 3.74" 1.50"
Mini Bend 29.13" 4.65" 1.65"
Universal Low 31.41" 3.15" 2.24"
Back to Top
Renthal Rider Bar Bend Width Height Pull Back
Carmichael/Windham 31.57" 3.90" 2.13"
J. Button-High Bend 31.77" 4.33" 2.63"
McGrath Mini Racer Bend 29.13" 4.53" 2.09"
McGrath/Lusk/Stewart 31.61" 3.62" 2.24"
Back to Top
Renthal Twinwall Bend Width Height Pull Back
CR High Bend 31.29" 3.74" 2.44"
Jeff Emig Bend 31.69" 3.66" 2.16"
Jeremy McGrath Bend 31.69" 3.26" 2.16"
Kevin Windham Bend 31.61" 3.62" 2.24"
Ricky Carmichael Bend 31.57" 3.89" 2.12"
YZ Bend 31.92" 3.34" 1.41"
Back to Top
Sunline AVone OSX Bend Width Height Pull Back
CR/CRF High Bend 31.29" 3.74" 2.44"
CRF/KXF/RMZ Bend 37.57" 3.89" 2.12"
KXF/YZF/RMZ High Bend 31.77" 4.33" 2.63"
RMZ/CRF/KXF/YZF Low Bend 31.33" 3.14" 2.24"
KTM Bend 31.81" 3.74" 1.49"
YZ/YZF Bend 31.69" 3.66" 2.16"
Back to Top
Tag T2 Bend Width Height Pull Back
CR Double High Bend 31.69" 4.53" 2.44"
CR High Bend 31.69" 3.43" 2.28"
CR Low Bend 31.30" 3.74" 2.44"
KTM Bend 31.69" 3.90" 2.56"
KX Bend 31.61" 3.35" 2.09"
RM High Bend 31.69" 3.66" 2.17"
YZ Bend 31.61" 3.62" 2.24"
Back to Top
Tag X5 Bend Width Height Pull Back
CR High Bend 31.30" 3.74" 2.44"
CR Low Bend 31.69" 3.42" 2.28"
Fourtrax Bend 31.10" 5.59" 3.35"
Mini Bend 29.33" 4.13" 2.48"
Raptor Bend 30.51" 5.90" 3.35"
YFZ 450 Bend 30.51" 5.71" 3.15"
YZ Double High Bend 31.50" 4.50" 2.25"
Z400 Bend 31.10" 5.51" 2.95"
Back to Top
Trail Tech ATV X-Bar Bend Width Height Pull Back
Low Bend 31.10" 3.27" 2.44"
Mid Bend 31.10" 3.74" 2.44"
High Bend 31.10" 4.21" 2.44"
Back to Top
Tusk T-10 Bend Width Height Pull Back
ATV Sport Model Bend 31.75" 6.25" 3.50"
CR High Bend 32.00" 3.75" 3.00"
CR Low Bend 32.00" 3.25" 3.50"
CR Mid Bend 32.00" 3.50" 2.50"
KX High Bend 32.25" 4.00" 3.00"
KX Low Bend 32.00" 3.50" 3.00"
Mini Hight Bend 29.13" 4.50" 2.75"
Raptor Bend 31.50" 6.25" 4.00"
RM High Bend 31.75" 3.00" 3.00"
YZ High Bend 32.00" 3.50" 3.00"
Back to Top
DrDsRaptor said:
Thats what I have, I think Pro Tapers site has a chart also with the measurements so you can compare... :thumbsup:
Guess I should have typed faster !! :lol: :lol: :lol:
Hey- Looks like I'm not the only "Big Mike" around here :thumbsup:.
I'll be going to get the bars today from a local shop.
Thanks for all your help guys.
Sure, when your incredibly good looking dating hot models was is easy for me,
but when it came to buying handlebars for my Raptor- I was stumped :confused:
Yes. Thanks.
I see you put the key switch where the reverse switch was- where did you move the reverse switch to?
I'll check the pics again to see if i missed it.
1 - 13 of 13 Posts
