1 - 12 of 12 Posts
I am wondering what is the next step to increase performance and power, but i dont want to get into boreing the motor...i have a slip on pipe, and an air filter, also a 15t sproket...what else can i do?
If you want more performance you will have to get a headpipe,fuel controller-power commander,cam,port polish,high compression piston,clutch. I would get new tires.
I stroked my motor with out going big bore and will give you a lot more power :thumbsup:
um... i dont know, it seems to run good! do i need a controller? will it help?
it will help alot :thumbsup:
is white bros a good EFI controller? and suggestions?
they are all good but would go with the power commander
dont they all do the exact same thing? no im not running with the lid off but i would like too!!!
these bikes run lean from the factory and the controllers all do the same thing but the powercommander you can just load your map based upon your mods and it will adjust @ 250rpm, its the most tunable controller in my opinion. the others you have to do the adjustments yourself, i think the powercommander would be good if you are like me and dont know enough to tune your machine for the best performance, or you can always dyno to tune, up to you. but yes you need a controller.
yes, the power commander is the one to go with in my opinion as well. You should get it as soon as possible, just to relieve some of the heat due to your machine running lean. Also make sure you do not run with no lid and no power commander as to it makes it run that much more lean, but without the lid on you will notice a nice boost.
1 - 12 of 12 Posts
