Yes the cap twists off the OEM wire, but the wire does not twist off the OEM coil.Does the OEM cap twist off the wire. I have two OEM coils that I may be putting on a 3-plug head. If I go that route instead of using a banshee coil I should be able to hook you up with one. Let me know if you still need one.
