1 - 13 of 13 Posts
I wanting someone who has accsess to a dyno to test a few spark plugs for the raptor to see if theres any power gain. The NGK CR10EK part #2360 adds 12hp to yamaha Apex sleds. Dyno proven. It has a duel ground which leaves the bottom of the plug open. Try these plugs. NGK CR8EK (3478), NGK CR9EK (4548), and NGK CR10EK (2360). I belive the Apex is supposed to have one step hotter plug, so going colder might work with these plugs.
Ammunition Spark plug Auto part Automotive engine part Bullet
The Apex has a four cylinder sled engine, and operates at a very high rpm, in excess of 10,000rpm, this is where a good or bad plug will show........
Yah, we put them in my dads 2 yamaha atacks 1000cc 4cyl. You could here the difference at idle. Way more crisp. Im hoping to see a couple hp gain on the raptor
I just found the sight. my #"s were way off lol. 12 hp was there air box mod.
Dual Electrode Spark Plug
Increase of consistant 2-3 hp in all 4-stroke applications
with iridium cr9eia-9 that we got from the garbage can that came from a kawi zx10, it gave my raptor 1.5-2 hp over all the powerband vs a new cr8e.tested and tested over and over. next week going to test cr9eia-9 vs cr8eix.
Try the CR9EKPA and it is the same about 1.5 to 2 hp gain according to a reputable builder and crisper throttle response. Mine should be here next week.
some builds like the plug and some dont.. on a stock bike or 3 mod u wont tell a difference over a NEW stock plug but the EKPA plug does show some hp gains when power is pushed further.... on a build around 70 hp u should see 1 hp thru the fat of the powerband with the EKPA plug
most people wont compare a NEW OEM PLUG to a NEW optional plug thats why so many people swear by the IX plugs
Well im pushing 18psi so hopefully a 2hp N/A gain would be a 4hp boost gain
Daniel - would the motor you built for me benefit from one of these plugs? Or is the compression close enough to stock to make it a non issue?
it would/ will, i may have put one in it already, not sure though
weve got em in stock if you dont have a local dealer
I went and picked up 2 of those CR9EKPA plugs at O'Reilly's, and my initial impression is that for $10 they are going to be worth it. I havent gotten my bike dynoed yet but I have been running the e3 3.38 plugs and I switched earlier after I picked the new ones up and they burn a lot more efficiently from just the eyeball test. I'll give them two thumbs up for the initial impression but I think that will hold true for the life of the plugs, in conclusion all I can say is WOW!
What spark plug recommendation do you make for a yfz? Stock bore/stroke with mild port and 13:1 piston.
1 - 13 of 13 Posts
