Pistons come with rings and wristpins. Cam uses the OEM decompression mechanism. Clearancing is not necessary with the stage 1. You'll need some top end gaskets including the one for the cam chain tensioner, assembly lube, and I like to keep a tube of Yamabond (RTV) around as well. Loctite is preferable also. Make sure your cam chain is in good shape, they're cheap to replace if yours is not but being an 05 it's likely in good shape.
