just washed the beast and after wards i went to go start and the little box with the two fuses made a little noise but nothing happend. everything is on but it acted as if everything was off. fuses are good. what else to check. im thinking its in the little box right there cause i got some water in it. i have a power probe and i just dont know where to start. "N" light on and that is it. please help
Give him some time to dry and chek the voltage on your batterie. It is suppose to be between 12 and 12.8 Volt. When your batterie power to turn the engine, that little box will do dad noise
make sure your neg & pos cable's are tight
some times they can rattle loose
