I had to tear my motor down because I broke a tooth on 2nd gear. I got it back together and I stalled again, but now it won't crank. My fuel pump won't turn on and I have no spark from the wire, but it turns over and the lights will turn on. Any help or ideas?? I wanna ride again haha
Was it running for a little bit and then it stalled?
Relay under the seat? main fuse or one of the other fuses under the seat? kill switch? tether switch?
Discussion Starter #4
Found it. Had 2 plugs on the tb crossed.
Now I have a new problem... it don't want to shift. I can make it shift if I reach down and snatch the lever by hand, but it won't shift smoothly by foot, and if I hold in the clutch and try to shift from neutral to 2nd, it won't shift and just clicks. I can also shift down into reverse now without holding the reverse switch.
I've got the same problem with my 07 700r, fuel pump wont prime when key turned on,an no spark at plug when turning over? I've cleaned earth wires but am unsure what relay is what
