Just got my motor back together and installed from swapping out the crap '01 tranny for the '02 and I've got zero oil circulation.
I poured a little over a quart into the tank, started it and checked for circulation at the check bolt on the side of the head and there's nothing. I also checked the level in the tank and it has not gone down at all from when I filled it.
I pulled the check bolt all the way out and could feel strong pulses of air coming from the hole, would this mean the pump is functioning properly? If that's the case, I'm assuming the screen in the bottom of the tank is plugged as I cleaned the case strainer when the cases were apart.
Any thoughts are greatly appreciated!
