I have an 07 700 and the fuel pump is not getting power when cranking. It primes when I turn the key off and on but I probed the connector and it doesn't get any power when cranking only when priming.
If I start at and hold the rpms up its will stay running but as soon as you slow down it shuts right off and will only start if you crank the engine while the pump is priming.
Not sure where to start, thanks in advance.
