1 - 2 of 2 Posts
Hi there, my first post, so be gentle!
Just picked up my first quad this week, a 700R. Took it for its first run out yesterday, used a whole tank of fuel - great fun! Filled up and as I went to pull off, it wouldnt start. The engine management light is flashing. After a few attempts at jump starting it, I turned to google. Found out the error code was 33 which relates back to the coil pack. Has anybody had any dealings with these before? Any problems etc. Ive changed the spark plug today just in case but still no luck! Not sure if it is the cut out cord or the ignition coil that is preventing it from starting!
i would first check the wires going to your coil pack. use a test light and see if your getting power there. if your are take your plug out and put it in the plug boot and crank it over and see if your getting spark.
if not i would get a different coil. any mods?
1 - 2 of 2 Posts
