Alright team.. Wondering if it’s possible to swap front end plastics or if able just the nose cone from 2014 model onto a 2008 model 700r se or it you can buy them to fit (kit) TIA
VIP
Welcome,
The hood and tank cover will not fit the 08 front fenders.
You will need new front fenders and can choose any color from 2013-21. You can pick any color hood and tank cover as well. The plastic stone guard for the rad is available in black, red and pastel blue. You will also need new front fender/headlight brackets, 2 spring clips for screws that secure the top of the hood, the Yamaha tuning fork emblem for the front of the hood and the smaller headlight trim rings from the 2013+ models.
Let me know what colors you want to get and I will give you the correct part numbers.
Welcome,
Thanks for your help mate much appreciated.. I would be looking to get the parts in black if you could sort me the part numbers that would be brilliant
thanks again 🤙
VIP
Thanks Six. You saved me a little bit of typing. :p
You will need the following parts to complete the fender swap.
If you click the part numbers it will take you directly to the Partzilla page or you can copy and paste into Google to search your area.
Front Fender/Headlight Brackets
Left- 1PE-F1513-00-00
Right- 1PE-F1514-00-00
Spring Clips For Top Of Hood.
90183-06069-00 Need 2
Yamaha Tuning Fork Emblem
4KN-2836B-10-00
Headlight Trim Rings
Left- 5TG-84165-01-00
Right- 5TG-84166-01-00
Foam Isolators For Front Fenders
5Y1-82122-00-00
1S3-21541-00-00 Need 2
3Y0-24183-00-00 Need 2
3B4-21541-00-00 Need 2
Foam Isolator For Tank Cover
90520-20001-00
If you are swapping the rear fenders you will need only 2 small isolators and the 2 pieces of reflective heat tape for protecting the fenders from the exhaust. You can order the factory ones or find a roll of heat tape and cut to size. Sixpack can post some pics of how he did his.
Isolators
1S3-2140A-00-00 Need 2
Heat Tape
1S3-2163A-00-00
1S3-2163E-00-00
Make sure to post before and after pics of the transformation for us.(y)
