1 - 20 of 49 Posts
Hello, I want to change my plastics, I have looked in partzilla but the problem is that I don't know how to decipher the codes to know the color, any ideas? Thank you
ok, I have this, could someone confirm it to me?
1PE-F1500-00-00 front fender blue ?
1PE-F171A-00-00 Cover top black ?
1PE-F3391-00-00 Panel front black ?
1PE-E2467-10-00 cover radiator blue ?
1PE-F1500-A0-00 front fender but i dont know the color
I appreciate any help
VIP
What color main plastics are you looking for?
What color front hood, tank topper and tail light panel?
What year is your Raptor and are you wanting to switch from the 06-08 style front to the 2013 and newer?
Be aware that the new plastics come completely bare without graphics, foam isolating pads, warning labels or heat tape shielding for the exhaust.
I want front fender blue.
Tank tooper and front hood Black or White
Radiator cover blue
I will use my full rear plastic
My raptor is a 2006, I know that I need a New front fender support.
Where to buy a warning labels? Thanks bro
Enviado desde mi SM-N9600 mediante Tapatalk
VIP
Hopefully this will help you out. I gave part numbers for both the black and white hood and tank topper. Be aware that the black is the cheapest option.
Front Fender
Blue #1PE-F1500-00-00
Tank Topper
White #1PE-F171A-10-00
Black #1PE-F171A-00-00
Front Hood (Radiator Cover)
White #1PE-F3391-10-00
Black # 1PE-F3391-00-00
Need Tuning Fork Emblem For Front Of Hood
#4KN-2836B-10-00
Radiator Cover (Stone Guard Under Hood)
Blue # #1PE-E2467-10-00 (More of a pastel blue color. Does not match fender color)
Black #1PE-E2467-00-00
Fender / Headlight Bracket
Left - #1PE-F1514-01-00
Right- #1PE-F1513-01-00
You should be able to drill out the rivets on your warning labels and carefully pry them off (they are glued on as well) and then transfer them to the new fenders with new rivets. What I did with my warning labels is after removing them, I covered them with a faux carbon fiber vinyl wrap and then riveted them back on.
I would also purchase the foam pads that attach to the plastic which they list as dampers. These isolate the fenders from rattling on the fuel tank.
You would need 1 of #2
2 of #3
2 of #4
2 of #5
1 of #19
Link to diagram....
https://www.partzilla.com/catalog/yamaha/atv/2018/raptor-700r-yfm70rsxjl-2018/front-fender
Discussion Starter · #7 · (Edited)
Front Fender
Tank Topper
#4KN-2836B-10-00
2 of #3
2 of #4
2 of #5
1 of #19
Link to diagram....
Thank you very much, what would be the code of the tank blue and front hood blue ? (I still can't decide if black or blue, the back of my quad is black) and this code to which color it belongs (it is very cheap $ 90 hehe)1PE-F1500-A0-00
VIP
Blue Tank Topper - #1PE-F171A-30-00
Blue Hood - #1PE-F3391-30-00
I've checked every year and model 700 and cannot find that A0 color code anywhere. Do you have a link to the page where you saw it?
Discussion Starter · #9 · (Edited)
VIP
Unfortunately that only shows the part number and not which model it is for.
I have checked all years and color combos and just don't see it on any parts list.
That is crazy how much the blue tank topper is, considering that the blue front and rear fender are by far the cheapest option.
When it comes to the hood and tank topper black seems to be the cheapest option.
For example...
Blue front fenders - $91.24
Black - $128.47
Blue rear fenders - $60.58
Black - $125.55
Black topper - $21.16
Blue topper - $16.78 Surprisingly cheap!!
Black Rad Cover - $43.06
Blue Rad Cover - $122.94 WTF?????
I found another site with cheaper prices on the main plastics but they have slightly higher prices on the hood and topper as well as the dampers etc. You may want to total your order from both sites and see what comes out cheaper.
To give you and idea here's a list of the front fenders for a 2013 700 with Blue front fenders from both sites. The front fenders from Yamaha Partshouse (Babbitt's Yamaha) are by far cheaper than Partzilla.
Babbitt's $91.24
https://www.yamahapartshouse.com/oemparts/a/yam/530b697af87002c148af3040/front-fender
Partzilla $111.75
https://www.partzilla.com/catalog/yamaha/atv/2013/raptor-700-yfm7rdl/front-fender
Discussion Starter · #17 ·
This is how it is, as this data these 2006 model presses do not work on the new plastic, any idea what to do?
VIP
I have not done the plastic swap personally, but have not heard of any problems with the clips from anyone.
Maybe someone who has done the swap will see this?
The new plastics look great. I especially like the blue rad cover stone guard.
Post some more pics from different angles when you can.
The new suspension will be your favorite mod by far. After switching my Raptor to long travel suspension, I could never ride with stock suspension again. :)
solve the problem using a car, the problem of that piece is that it is shorter and does not focus on the holes of the new plastics, as I did not want to modify anything because I could get other, just fear of putting together everything I send the photos
1 - 20 of 49 Posts
