21 - 40 of 49 Posts
Hi im new here i want to change the plastic on my 700 for the 2020 SE grey and maroon color does anybody know the part number for the front and rear fenders thanks
VIP
Welcome to the forum.
You can click on the part numbers and it will take you to Partzilla. If you have an 06-08 700, you will need some additional parts to complete the swap.
Front Fender Pastel Grey 2LS-F1500-00-00
Rear Fender Maroon BCX-F1600-00-00
Front Hood Maroon 1PE-F3391-80-00
Tank Cover Maroon 1PE-F171A-80-00
Yamaha Tuning Fork Emblem (Front of Hood) 4KN-2836B-10-00
Administrator
That should be all you need. Look at the parts fische on the site and maybe grab some of the foam pieces and heat shield tape for the exhaust area. The head light brackets will be called a fender stay in the fische.
Great choice on the color, really has me thinking of doing the swap on my 06 in that now.
Reactions: Lat
Those two color combinations looks great and yes had the foam pieces and the shield in mind also thanks
VIP
Chimbazoid Thanks for the info👍👍mine is 2007 Im guessing I just need the headlight brackets for the swap or is there something else that i need ?
You're welcome.
You will need the following parts for the swap.
Front Fender/Headlight Brackets..
Right 1PE-F1514-00-00
Left 1PE-F1513-00-00
Clips For Hood (Need 2) 90183-06069-00
Radiator Stone Guard (Pick One)
Black 1PE-E2467-00-00
Red (2018 SE) 1PE-E2467-20-00
I've heard you also need to swap the headlight bezels, as the 06-08 are larger.
Right 5TG-84166-01-00
Left 5TG-84165-01-00
Links to front and rear plastics, if you want to order the foam pads and heat tape.
Front
Yamaha ATV 2020 OEM Parts Diagram for FRONT FENDER | Partzilla.com
Rear
Yamaha ATV 2020 OEM Parts Diagram for REAR FENDER | Partzilla.com
You're welcome.
Front
Rear
Thanks
Administrator
The parts for the maroon colors I ordered back in March of this year are finally being shipped out and I should have them by tomorrow at some point. Decent weather this weekend, so at some point I will swap them out and post a before / after on here.
Thanks again for all the knowledge you possess there @CHIMBAZOID. Your parts # logging data has been pretty spot on for a lot of members looking to change the colors.
Administrator
Here you go @CHIMBAZOID . So, I need to figure out how to establish my pods on the new brackets, at least one set. Also a new seat color design will be coming up to match better. All stuff will be tweaked over the cold months. This has been a long wait since placing the order in March. Couldn't reuse my flame grill cover so that might be up for sale, I don't know yet.
Wheel Tire Vehicle Automotive tire Tread
Tire Wheel Automotive tire Tread Motor vehicle
Sent from my LM-G710VM using Tapatalk
Reactions: Sixpack577
Administrator
Sunny weekend will have better outside pics anyway. One other plastic piece that people might want to order would be the underside brake light housing. Once I pulled the rears off I realized what I needed, so that might be another part on my list to order…
VIP
Not a problem Morph. (y) Glad I can help with the part numbers, as they can be confusing the way they are listed on the parts diagram.
Looks amazing. A new seat cover and tail light panel and it could be easily mistaken for a 2020 at first glance.
It makes me want to upgrade to the newer style front end now, except for the fact it would cost me more than double what you guys pay with the dollar conversion. The shipping costs are insane for oversize boxes, as well as the brokerage fee we have to pay when it crosses the border.:confused:
The 2013 and newer models only came with a black tail light panel no matter which color the main plastics were. The 06-12 models have a choice of black, blue, white and dark grey metallic, all of which will fit the newer models.
I have this style radiator guard.
It works with or wihout the black honeycomb grill in the 2015-2021.
It fit great, but I took it out as it is blocking some air flow, but I noticed no difference on the temperature gage.
Font Rectangle Screenshot Electronic device Software
i need help with the colors for the raptor 700 13 and up stuff i want the fenders all in black and the nose and tank cover in the orange can you help me with that partzilla does not no the colors
Hopefully this will help you out. I gave part numbers for both the black and white hood and tank topper. Be aware that the black is the cheapest option.
Front Fender
Blue #1PE-F1500-00-00
Tank Topper
White #1PE-F171A-10-00
Black #1PE-F171A-00-00
Front Hood (Radiator Cover)
White #1PE-F3391-10-00
Black # 1PE-F3391-00-00
Need Tuning Fork Emblem For Front Of Hood
#4KN-2836B-10-00
Radiator Cover (Stone Guard Under Hood)
Blue # #1PE-E2467-10-00 (More of a pastel blue color. Does not match fender color)
Black #1PE-E2467-00-00
Fender / Headlight Bracket
Left - #1PE-F1514-01-00
Right- #1PE-F1513-01-00
You should be able to drill out the rivets on your warning labels and carefully pry them off (they are glued on as well) and then transfer them to the new fenders with new rivets. What I did with my warning labels is after removing them, I covered them with a faux carbon fiber vinyl wrap and then riveted them back on.
I would also purchase the foam pads that attach to the plastic which they list as dampers. These isolate the fenders from rattling on the fuel tank.
You would need 1 of #2
2 of #3
2 of #4
2 of #5
1 of #19
Link to diagram....
Yamaha ATV 2018 OEM Parts Diagram for FRONT FENDER | Partzilla.com
i need help with the colors for the raptor 700 13 and up stuff i want the fenders all in black with the tail light under cover and the nose and tank cover in the orange can you help me with that partzilla does not know the color codes please help
Administrator
Hang tight frizyme, @CHIMBAZOID will eventually see this and let you know.
VIP
Patience my friend. We all don't spend the entire day looking at the computer or our phones. I check the site once a day and just saw your 3 messages.
Click on the part numbers and it will take you to Partzilla to order.
Front Fender Black 1PE-F1500-40-00
Rear Fender Black 1PE-F1600-40-00
Front Hood Orange 1PE-F3391-40-00
Tank Cover Orange 1PE-F171A-40-00
Tail Light Cover Black 1PE-H4716-00-00
You will also need the following foam isolators, heat tape and hood emblem.
Foam Isolators For Front Fenders
5Y1-82122-00-00
1S3-21541-00-00 Need 2
3Y0-24183-00-00 Need 2
3B4-21541-00-00 Need 2
Foam Isolator For Tank Cover
90520-20001-00
Parts for rear fenders.
Isolators
1S3-2140A-00-00 Need 2
Heat Tape
1S3-2163A-00-00
1S3-2163E-00-00
4KN-2836B-10-00
21 - 40 of 49 Posts
