so i was thinking about it i could easily fit a cooler in front of my radiator under the the guard, i was thinking of cutting the oil return line from the motor hook up a new line have it feed into the cooler and then back to the top of the oil tank, only question is dose the factory oil pump put out a nuff psi to be able to to do this with out starving the motor for oil
here is the cooler i plan on picking up in the next few days if it's in stock http://www.summitracing.com/parts/DER-13212/
reason for doing it is peace of mind as im ruing a mean 727 with 14-1 comperson
i have an oversized antivibe steam so the bigger oil tanks will not clear
I dont forsee any problems, we have done this with a lot of our YFZs..............
I've had a oil cooler for mine for years but never put it on just scared the stock oil pump wouldnt put out enough to support it. Its a good idea tho. Keep us posted.
i hooked it up sunday but i haven't gotten to take it out yet other then a 1st gear putting around the yard
