K so my 06 raptor 700 leaks oil only out of both plugs I keep toping up the oil tank do I need to keep putting it in the motor to or dose the tank feed it in there kinda a stupid question but when I guy dosnt know better off to ask people that do it also had a crack in the case by the shifter that useto leak but dosnt any more with some help from JB weld lol I traded my little enclosed trailer for the thing and don't know much about it had a 08 Kawasaki kfx450f before this and this is ten times the quad off the track
Not 100% sure I follow, however, if it's leaking a little and you need to top it off a little, you can just add it to the tank.
Discussion Starter #3
So if I'm topping up the tank the motor should be good like when I change the oil in pretty sure I but a quart in each but since then iv just been topping up the tank it doesn't leek much like maybe a 2 inch circle on the ground in the morning
