1 - 14 of 14 Posts
Having trouble finding the link to the "willy oil mod". I found lots of threads that mention it but no luck finding it.
I could be wrong ,but,the oil mod is for the YFZ 450.Scott.
I dont think willy has ever told anyone about it....
Its his little secret.
the oil mod is for both yfz and 660...
If you want to know about MY oil mod, just pm me.................
What is this mod all about?
Please pm me your email address.
Sorry about not seeing your request.
I've had a serious tragedy. My shop burnt two weeks ago.
The "Oiler Mod" I am familiar with relates to early YFZ450's and it probably effects the 660's of the same years too.
For the 450, prior to 2007 or so, there was a problem with the crank not getting enough oil at high revs - so the story goes.
The fix is, when you rebuild your motor, the case has to have a new hole drilled in it to allow for proper flow and then the oil pump gets replaced with a higher output model from the later years. The result is a new squirt that hits closer to the wrist pin.
At least that is how my highly concussed brain remembers it....
I had my mechanic do it to my YFZ a couple years ago.
2005 Raptor 660 (bored to 672)
Good day WillyKiller, I trust that you are well.
I would like to find out whether the details are still available for your oil mod to keep the top of the con-rod lubricated?
My email is [email protected] if it is still available. I also sent you a PM.
Kind Regards
Dion
1 - 14 of 14 Posts
