So my buddy has a 686 raptor and we just made it to the riding park but when we went to check the oil level after two min of riding the oil will overflow out of the dipstick hole...the drain plug on the bottom broke loose a week ago and we used some hondabond ht to hold it together until the new one arrives...any ideas on the overflow?
If you checked the oil level after fixing the oil tank when it was cold that is your problem. It is likly over filled. You check the oil level hot with the raptor. If it is on the full mark when cold it will be way over full when hot.
check your coolant level... if its really low (as compared to normal)...drain the oil and make sure its not looking like chocolate milk
