1 - 12 of 12 Posts
ok,,,ive never used helicoil,,,how do you do it???
You can get kits at almost any auto store. I got one at Advanced Auto for about $$15, They come with a drill bit , tap & instilation tool. You just remove the broken bolt or whatever, drill & re tap , then insert the helicoil. It's not a bad idea to use a bit of locktight on the new coil.
Good luck, Chris.
no, should be able to do it like it sits. good luck
1 - 12 of 12 Posts
