1 - 2 of 2 Posts
need opinions ..... FACTS AND DYNO sheets would be nice too !!! :)
I got my 727 all bolted in and HOPE to fire it up this weekend ...
motors has: stage 3 cam, ERE ported head, 11:1 105mm, HC crank, 93oct
have a dynatek too .... would love to talk curves and rev limits ...
and LOTS of options on EVERYTHING ELSE !!!
exhaust ... here's what I have to choose from ....
alien 2 into 1 ... my #1 :D
yoshi ... too quiet ....
FMF .... about the middle ....
choices for airbox ..
stock ..drilled ... cut ..reamed ... hacked ... etc
UM no lid box ....
2into1 no name aftermarket aluminum box with a lid .....
no box ..... dual clamp on filter .... how are they in the mud and water ?
carbs .....
stock ... jets ??? ... 180/185 ish ??
FCR 35mm ... jets ??
FCR 39mm ... jetting ??
Yoshi, depending on which one it is. If its the cheap one and you can't pull out the tec kit, go with the alien. (since you rated them, none of these would be in my top 3 for your build)
Dual clamp ons if you want power, UM if you want to play in the mud or the no name one depending on which looks like it will breathe better through the intake runners.
35's will do the trick, 39's if you can get 'em for around the same price.
1 - 2 of 2 Posts
