Hey guys i have a 2002 660 raptor thats leaking gas from the overflow tubes and its bogging under load and it gets worse the warmer it gets would this be a problem with the needle and seat ? Any help would be good thanks
The float valve on one or both carb is leaking - whether needle, seat or o-ring under the seat (or just gunk holding it open) is up to you to determine by inspection.
This will also cause the engine to run rich, and the warmer it gets the richer it will get - the cause of the bogging.
Time to THOROUGHLY clean the carbs. If there's problems with the float valve, there's likely problems (varnish gunk) everywhere in the fuel wetted areas.
