That's sucks, sorry to hear about your misfortune
For those of you that do not know what an Override Tranny is,
with an overide tranny you do not use the clutch to upshift, you just pin the throttle and go thru the gears, that's the purpose of it, however the drawback is if you have to chop the throttle or let off the gas for any reason you have to pull the clutch in or it tears shit up internally.
That's why I will never run an override on my duner/hill shooter, to much can go wrong to fast and the last thing you think about is pulling in the clutch when shit gets hairy.
It's the prefered set up for flat drag's and some hill shooters run an override. I have seen claims of dunable overrides but I have not heard of anyone having any luck with them if they forget to pull the clutch in under power. Same story everytime, back to the builder for repairs. Just not worth it IMHO
If you want to use your bike for anything else other than just a flat dragger I would not reccomend an override trans. Train your self to fan the clutch when you speed shift. Just my .02
