Hey guys, Just replaced the clutch lever on my 700 and did the block off plate. What do I do with the PBS Sensor? Is there a plug that I follow down and remove? I looked for a thread but didnt find anything for the 700. Right now I have the two wires connected and taped together.
Also in RE : to the speed sensor removal. I read the sticky but was unsure if I should do this if I still plan on buying a PC5 in the near future.
The UK's fastest Raptor
those wires are the clutch sensor not the parking brake. The switch stops you starting it in gear without the clutch pulled in.
Okay thanks, but is connecting the two wires okay? Right now they are connected and I think I started it in gear when I rode they other day it one time. Typically I start it in Nuetral because that is what I have allways done but I am pretty certain I started it in gear.
What did you guys do with the wires?
Connect them together, shrink tube, and tuck them away.
right on. Thanks.
