1 - 10 of 10 Posts
Two days ago I was riding at the local pit, when i saw a dollar bill on the ground :D, so i parked my quad next to it (on a hill), and put on the parking break, and let off the foot break. I immediatley started rolling backwards,wonndering why.??? I turned the parking break off, and then back on. Same happened.:mad: i looked at the cable that attaches the lever to see if it got detatched, but it didn't, and it looks fine. It even tightens when i tun the lever. I was just wondering, whats the problem??
The parking brake needs regular adjustment (using that bolt and locknut in the center of the PB assembly by the caliper)- as the brake pads wear, the PB needs to be adjusted accordingly - it's not automatic.
I don't know many ppl that have a working PB anymore - except for my Polaris, which locks the hand brake lever directly - keeping hydraulic pressure on the brakes.
thanks, but when you adjust it, is it as simple as tightening a screw, or do you have to tighten/ loosen it, and test it, repeat, repeat.
Just tighten so it grabs when on, releases when off... not a lot of test and repeat required.
eliminate the parking brake. its junk.... it needs adjusted every 5 mins of riding for it to work... at least on the the 660
they never work you just have to turn the quad off and put it in first
Ive had my quad since 2007, and my parking brake still works great. Never had a problem with it. :d
1 - 10 of 10 Posts
