Where did you get lost? :brick:bgmac said:Just disconnect the plug with the two wires running into it from the clutch/perch. Then just zip tie it somewhere out of the way.
Limited660 is right, Sorry! I am still new to forums. Easily confused. :banghead:ursuaja said:660rider is right. It will do the exact same thing as cutting the wire does. Doesnt allow the circuit to go to ground.
Sounds like there is another problem.
That sensor button should be open. When you engage the parking brake it pushes in on that sensor. Can you start it in gear while holding the clutch in? If you can't its definitely the PB sensor.660ryder said:thats what i did and it still pops and sputters. so i plugged it back in and pushed the sensor button down and it was fine??? what the hell do i have to unplug it anywhere else or just that one spot?
