1 - 1 of 1 Posts
All right so I put my 700 back together and it will not start with the PC3 hooked up. It will start and run on the stock map but it is WAY to lean obviously. I got the PC3 hooked up right. I did not have it hooked up right at first had the wrong connector but got that figured out. It powers up and will come on. When plugged in my computer I can read the TPS and RPM's when cranking over but it will not start. Loaded another map on it and still no luck. I am gonna pull it off and check all the wires tomorrow and make sure nothing got messed up but I don't think anything got messed up. There is just 2 injector plugs, 2 TPS plugs and a ground correct. I tied all the PC harness to my stock harness when I installed the motor so it don't come out easy. Kinda wishing it had a carb on the thing now:p They are simple to trouble shoot.
What ya guys thinking.
1 - 1 of 1 Posts
