I have a 2008 raptor 700 se 734 trinity big bore ,intake ,stage 3 hc i had it dyno'd about 6 monthes ago. My battery died . Now my question is do i loose the map i had ?? And will it hurt it if i run it before i tune(download again) it.
9v is so you can adjust your pc3 with out starting the bike. If your not sure you can always plug your laptop in and check only takes a second.Actually the battery on the quad and the guy who checked it told me that i had to reload the map . He also mentioned somthing about that 9v adapter.what is that used for ?
