1 - 15 of 15 Posts
Ok no major mods here but still need to a map for them:
Stock exhaust with sparky and baffle removed
Monster Intake with Uni Foam Filter w/Pro Tec Lid
I did also add a filter to my crank line to filter it better (not sure if that matter prob not but just in case)
Oh and a PC5 too...
Map #3 from the Dynojet PC-5 maps will work fine.
Really? Ok thank you very much. I guess if i could buy that autotuner i wouldn't really need to worry about that would i? Is everything is perfect working condition on it? Would i need to do anything with the maps if i got that and installed it?? Would you do $125 shipped?? Had to ask...
one other question. when i go to download the maps from power commander.com do i tell it i have a raptor 2009 - 2010 to get the pc5 maps? I think if i choose the 2008 it only gives me the pc3 maps.
Correct, to get the PCV maps you need to select 09 or 2010 model.
Speed's Best Friend
Yes, everything works. Autotune will actually suggest changes to the base map you have installed. You probably wont see a lot of benifits until you have done some more mods. It is pretty complicated for the novice (myself included). Do you have a place to ride near your house with out having to trailer it? That would help the tuning process. Ive got it listed on Ebay now with a Buy it now of $150 + Shipping. I have about 5 days left, but several watchers. If it dosent sell here or on Ebay, by auctions end, Ill take your offer.
I have a place pretty close but I do have to trailer it though. Ok let me know. Thanx
another question related to the pc5 after i hook my laptop up to my pc5 and get the software up when do i start my bike up?
Speed's Best Friend
Right away, the program will show your RPMs, you can then switch maps. You may even be able to switch maps with out starting you quad.
after doing a little digging this is the closest map i found
DL700's custom map DMC force 4's trinity intake no lid pcv Unknown elevation
The only differ is that i am running a monster intake with a foam filter will this map work or should i try to find a more specific one that included the monster intake?
I looked a the powercommander website and didn't find anything referring to the dmc force 4's exhaust.
that should be good. but here is a link to a site of pc3 maps. but the pcv software will convert them. http://www.bob2bob.com/
ok so i used dl700 map and fired her up. after about 5 minutes the headers 4 inches from the engine got pretty red. Is that normal? Or is it a bad map?
The header pipes will turn red, I thought the same thing after i did mine, but after researching a ton, glowing headers are normal for the raptor 700 running duels
hi sorry if this isn't the right place to post. I'm new to this,
I have a 2006 raptor 700 with dmc megaphone duals w/o spark arrestors, fci intake w/box and a pc5 fuel and ignition,
I'm looking for a map to suit this or at least a base map so I can continue riding until I find a dyno,
thanks in advance for any help
1 - 15 of 15 Posts
