VIP AKA Corn Dog
So, are people using this utility? What is the general opinion on it? I have seena few people post they use 80-20-20, and others say they removed it. Any reasons why to or not to use it? Any help is appreciated...
It depends on how your fuel injection is set up.
If it is set up to run at 13:1 across the RPM range and you activate the accelerator pump to add even more fuel, then it will rob power. If the PCIII is set up to deliver around 14:1 A/F ratio and you activate the accelerator pump to supply more fuel and richen it up a tad, then yes, it will add more power.
Try it, maybe you like it, maybe you don't.
VIP AKA Corn Dog
And how do you tell?
Zdogg, if your running my map you don't need the accelerator pump feature enabled, unless for some reason your bike is not running as well on that map as it should. The A/F ratio on the map I sent you is right at 13:8.1 as that was where I got the best overall HP & TQ numbers on my setup at the time. It worked very well for me for over 200hrs of hard duning and hill racing.
Randy
