Pity is freely given, Jealousy is earned
I have stock 07 and just put a PCIII on and it wont idle longer than 30 seconds. I double checked to make sure i had the right map and i do. The throttle is at 0% and the RPM jumps around from 1200-1400 RPM. From what i read here on the forums and im thinking i need raise the idle on the throttle body. Is there anything else i need to check before doing that ? Anyone have an idea what the idle should be a for stock raptor ?
mine are usually about 1600 or so, not sure what it calls for. u sure its not rich at idle? check the plug and make sure it isnt black
Service manual says 15-1700 rpm.
does the percentage increase/decrease when u give it throttle and let go? ive read of people having a firmware problem but not usually on the III's just the V's.
Haven't checked the plug yet so ill do that. I think I will also try the others stock map that has no lid and see if that makes a difference. The throttle % is at 0 when idling and dose go up if I rev it. Is there a way I can check to see what firmware version I have?
