741 - 753 of 753 Posts
Hey guys m, I'm new to this forum.
I'm running a 2007 raptor 700 with a power comander 5 and fuel control.
K&N air filter - no lid
5mm stroker crank
CP big bore kit with high comp piston head
Complete Empire dual exhausts system.
Any idea of the best map to start with as a base?
5mm stroker crank
Sorry, but I don't think you'll find one here. This thread is about the PC3.
It would be best if you start your own thread.
WELCOME TO THE FORUM.
Hey y'all I'm needing a map asap!! Lol I have a 2008 raptor 700 with the pc3 and I have:
Barker duals
Stage 3 hotcam
Fci with open filter
Dynatech coil and plug wire mod
Thank y'all. And I would also know if y'all could give me some what of step by step on how to download the maps and what to look for like the throttle positioning
I could use several good PC 3 maps. One at sea level, one at 3000 feet, and one for 5000 feet. Basically glamis, home, and St. Anthany. My build is a +2 head ported with a 54 throttle body. It has a Denso 600 injector with a 5150 cam, and a stock bore stock stroke with a 14.1 piston.
I'm having a difficult time finding a map for the Sparks Big Core, and FCI Intake w/box. Can anyone point me in the right direction? I checked Krandall's site with no luck for Sparks anything, and I saw a post reference a bob2bob thing, but I don't know the link to that site. Thanks in advance.
PCV map
You do realize that you can convert PC3 maps to PC5 maps in the PC5 software, right?
I'm in need of a map. I have a 105.5mm bore with a 11:1 cp piston, stage II hotcam, full Yoshi exhaust, dynatek coil, stock tb, airbox lid off, and a PCV. The elevation here in OK is 1300 ft. Can anybody help me out?
I'm looking for a map. I have an 08 700 raptor and just had dmc force 4, hotcam stage 3, pc5, and cp piston 11:5:1 installed. It has the stock airbox with no lid and foam filter. My bike is running a little lean and was lookong for a map to get it running better. Any help would be greatly appreciated.
Did u find a map for this. I have same setup and have been looking forever.
Sent from my SM-N920V using Tapatalk
Map
Hello, I need a map if anyone has
Cory Kramer
mods-
Gytr filter-no lid
+3 tb
HC stage 3
10.5 compression
Dmc Force 4 Duals
Power-commander 5
Anyone have anything, would greatly appreciate it
