Okay, I am a newbie here and just want to see which would be the better starting point.
I have the 06 raptor 700 with PCIII, sparks x6 exhasut, k&n with pro-flow, the air box lid pre-filter and the 15t front sprocket. I acquired the quad just recently and the previous owner told me that he was running the newer richer map for the PCIII. Is this the best map or should I try the original map for the above setup? I did notice that it want's to pop on decel and also some popping in the upper rpm range.
Whatcha guys think?
Thanks
Re: PCIII suggestions...
What newer and original map are you talking about. I didnt know there was original and newer. Go to power commander website and see if they have the same mods you have for a custom map. Welcome to the site :thumbsup:
Here are the two different maps from thier website:
m416-007 - Curtis Sparks X6 full exhaust Curtis Sparks Racing Filter Charger Airbox lid removed
m416-007b - Curtis Sparks full exhaust Curtis Sparks intake kit Airbox lid removed Note: *REVISED MAP* This map is slightly richer than map M416-007
These are the closest maps to what I have. The only difference is the airbox lid removed and I have the EHS air box lid with the outwear built in and I have the K&N with proflow and these maps show the sparks intake. I am currently running the m416-007b.
Any other thoughts on the matter?
Thanks
does anyone have any experience with either of these maps? any recomendations?
Thanks
