Yep sorry another PCIII for dummies question.......
Installed the PCIII and the bike starts and runs so I guess thats one thing.
Problem is I can't get power to the unit in order to transfer maps.
With bikes ignition on, a green light appears on the PCIII and dissapears after a second or so. Sometimes it doesn't come on at all. Also tried using the 9volt power supply with same result.
Also how do you know when map has successfully loaded?
:help:
for some reason mine does the same thing. I just put the 9v with the adapter on, turn the key on, then load the map. It has worked and held the map so i just accepted it and moved on.
