Hi there,
New to the forum, and just got myself a 2008 Raptor 700R.
It has the stock exhaust with muffler insert removed, airbox lid off and a powercommander III USB.
Question is, can i run the following map on my ride;
"M416-003" "Stock exhaust with muffler insert removed Stock air filter Airbox lid removed"
When opening the map in the PCIII program it says that its for the 2006 model 700 Raptor.
Is there any differences between these rides, or will this map work for me?
Map number/ description is from powercommander.com
Thanks guys!
The reason Im asking is cause mine is a 2008. Not a 2006.
Will it still work?
Also, I just found out i have the gytr air filter insert (open filter).
I loaded the map Im talking about above, and she seems to sputter and backfire once in a while. (Not too often ...)
I am totally new to this, and it may be normal?
Just looking for some input from you guys with better knowledge about this.
Can i still use the same map, or what do you recommend?
Thanks guys.
That's awesome. Thanks a lot. 8)
I wanna test out my DG slip on exhaust, still with GYTR open filter no lid.
What kind of map should i use for that?
