I need to find a PCV map for my Raptor, it has a 734 big bore kit with 11.5:1 piston, 4" aluminum air box (no lid), barker dual drag pipes, I havent found any tunes for the big bore that didnt have the cam done aswell, just wondering if anyone can help
If no one chimes in i guess its dyno time for you or get the auto-tune for the PC5...Wish i could help...
You are running Barker out of frames with that small of a build?
I found a tune that seems to be working alright for now, but I am going to get the auto tune. I don't want to spend the money to use the dyno because I plan on doing the cam in a while, just can't afford everything at once, and I'm running the out of frame barker duals cause I got them for cheap, $160
They are probably going to hurt you performance wise. But i guess i understand cheap.
