1 - 1 of 1 Posts
I have the PCV with timing (model 22074) on my 2015 raptor and it doesn't seem to be adjusting the timing even though I have tried all different values from -10 to +10 all the way through the range from idle to 9k. When I look at the real time gauge panel on my laptop, the ignition adj stays at 0 while all the other gauges like fuel adj change to the values I have programmed. I called PC and they are clueless. Any ideas? Could it be malfunctioning? There's no error codes...
1 - 1 of 1 Posts
