Does anybody know how many turns out from the seated position the pilot jet needs to be on the Raptor 90 carburetor. I was cleaning the carburetor and I forgot to count when I took it apart. Any help would be appreciated because I have no idea how many turns it should be.
I normally start at 1 1/2 turns, and then follow the procedure below. There has been a lot of threads on the site that talk about increasing the pilot jet size and adding side air vents. I have taken my daughters to a .39 and it really is running great.
1) Warm up the engine to full operating temp.
2) Turn up your idle a few hundred RPM using the throttle stop screw (basically you want a fast idle). This will make it easier to hear small changes in RPM. Watch for overheating--pointing a big shop fan at your engine will help it from getting too hot during the fast idling. The whole procedure shouldn't take too long though.
Each time you change the screw setting 1/4 or 1/2 turn or so, wait about 5 seconds to let the idle speed normalize. It usually take the carb and engine a moment to react to the change.
3) Turn the fuel screw IN until the idle starts to drop and miss. The engine should die if you bottom out the screw. Your pilot jet is too big if it doesn't die when the screw is bottomed out--it should die before it gets that far in.
4) Then begin turning the fuel screw OUT. The idle should peak and become smooth. Keep going and look for the idle to begin to drop/miss again.
5) The goal is to find the setting that provides the highest and smoothest idle. If it's unclear exactly were that point is then set to the midpoint between step #3 and step #4. For example, if the idle starts to drop at 1 turn out and starts to drop at 2 1/2 turns out then 1 3/4 of a turn out should be the correct setting.
If the peak/smoothest RPM is reached somewhere between 1-3 turns then your pilot jet is correct (the 1-3 turns applies to most carb types). If you end up less than 1 turn out then your pilot jet is too big and you need a smaller one. If you end up more than three turns out or the fuel screw seems to make little difference as you continue turning it out than you need to go up (bigger) on your pilot jet.
To re-emphisize: If the idle never drops when you're turning the fuel screw in, you need a smaller pilot jet. If the idle never drops when you're turning the fuel screw out, you need a bigger pilot jet.
Typical fuel screw settings are in the 1 1/2 to 2 1/2 range.
6) Once you've got the fuel screw set, re-adjust your throttle stop screw (idle screw) to an appropriate idle speed.
And that's it! Your pilot circuit is now VERY close to ideal. From here you can experiment with how small adjustments affect low-end (i.e. small throttle openings) response and make adjustments for weather. The hardest part is usually gaining access to the screw while the engine is running. Also, you may really have to listen carefully to detect the rpm changes in the idle. 100 or 200 rpm differences can be tough to detect when the change happens over several seconds.
